FloridaSPL (https://www.floridaspl.com/forums/index.php)
-   SPL & SQ (https://www.floridaspl.com/forums/forumdisplay.php?f=32)
-   -   thinking about switching to a 4th order (https://www.floridaspl.com/forums/showthread.php?t=28108)
KyleBechtold 07-24-2013 09:25 PM
I have 4 sa 8 v1.5s in a ported box. Thinking of switching to a 4th order. I know with the qts they are not ideal due to the sealed section of a 4th order. I have a good bit of space and think I can make it big enough.
My question is what kind of ratio should I look at. I want to find out if I have enough space and then get with someone for a design. My goal is to get a louder low end 28-32 is where I usually like to play.
I saw a ratio a while back someone was happy with, but can't seem to find it.
If this is out of the picture I will rebuild my 18" BTL and drop it in the truck.
FLAstrongman 07-24-2013 09:39 PM
I really hate the way SA 8's perform in a 4th order.
KyleBechtold 07-24-2013 09:43 PM
I thought you had good luck with them? I remember you building a box a while back.
I may just need to alter the direction they fire and lower tuning a notch. They fire up in my truck and I can't ever put my rear window down or the bass is completely gone. I can do the rear side windows no problem though. Also the tuning is a little higher than I care for.
GetDown 07-24-2013 09:46 PM
why don't you just add some port length?
KyleBechtold 07-24-2013 09:49 PM
not an option its kerfed and just about at the top of the seats. It would look awful.
http://i35.photobucket.com/albums/d1...a/SAM_0149.jpg
GetDown 07-24-2013 10:05 PM
i see
FLAstrongman 07-24-2013 10:38 PM
yeah I got them to sound pretty good, that does not mean they did not perform a whole lot better in a ported box.
cheap sleeper 07-28-2013 04:36 PM
Interesting info. I'ma remember that if I ever decide to play with a couple of those. ported it is!
suni123 10-10-2013 02:27 AM
PHATBOi 10-10-2013 09:13 AM
:confused:
