Direct connect wire - FloridaSPL
Old 03-16-2013, 02:26 AM   #1
MrSublime1420
Junior Member
MrSublime1420's Avatar
Default Direct connect wire
I've notice that some sub woofer companies offer direct connect Wire option for their subs. What is the benefit of opting for direct connect versus the spring loaded connectors?
MrSublime1420 is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 06:02 AM   #2
TheJesus
TheJesus's Avatar
Personal preference mostly. I don't use anything with the springs anymore because they are usually too difficult to push and place the Wire in or aren't big enough for the wire you're trying to use. I've had two of my 16 subs so far be the springs, and I removed them when I reconed. Direct leads are so much better.
Loudest Challenger in the world
"You won't be able to see a difference because subs move like fast... and stuff" -TaylorFade
TheJesus is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 06:37 AM   #3
monoxide
monoxide's Avatar
Send a message via AIM to monoxide Send a message via Yahoo to monoxide
My subs have the springs and I can barely fit my wires in them to Wire the 2 of them to .5 ohm
monoxide is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 07:16 AM   #4
BIGJEFF64
BIGJEFF64's Avatar
Some say that it's less resistance when they are direct connected like another link in the wiring chain. Some swear by it others not so much. It's just something else to try for ur own application.
BIGJEFF64 is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 08:22 AM   #5
Sweendog
I've been told to stick with push terminals, I don't think it really matters when it comes down to it.
Sweendog is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 10:08 AM   #6
bass wrench
Remember your talking ac volts. So wire size is totally different.
bass wrench is offline   Reply With Quote Quick reply to this message
direct connect, subwoofer
