Walled Ford Explorer with 8 Loudforce 15s , at last :) - Page 2 - FloridaSPL
Old 12-07-2013, 07:10 PM   #11
olympus pounder
olympus pounder's Avatar
Looks good. Can't wait to see it finished.
2011 1st Place INAC Stock 2
2011 3rd Place INAC Featherweight Bassboxing
2012 1st Place SBN Featherweight Bassboxing
2012 1st Place SBN Stock 1 Suv/minivan 152.1 DB
Not bad my rookie year
olympus pounder is offline   Reply With Quote
Old 12-07-2013, 07:18 PM   #12
fecupe2001
fecupe2001's Avatar
thanks jason, me neither :)
Panamenian 149.9 Bass Race 2009 & 2010 champion.
fecupe2001 is offline   Reply With Quote
Old 12-07-2013, 10:08 PM   #13
fecupe2001
fecupe2001's Avatar
Second baffle on!! it was a little bit tricky, i knew how big i wanted the sealed chambers , but, didnīt know exactly how many degrees they nedeed to be angled, my boy keith miller (loud as **** white jeep with 12 dc audio 12s) told me his best results have been using only 3" angles, in other words, the back of each sealed chamber is like 9.75" and the front are 6.75".
starting to brace even more the sealed chambers, 5 3/4" threaded rods on each side
Test fitting the top of the box before adding more angle steel....
Done!
Old 12-08-2013, 07:45 AM   #14
jlm1216
Awesome.
Team flying pink dildo
Worlds loudest red 2003 ford expedition with tan interior on 9.5 volts
jlm1216 is offline   Reply With Quote
The Following User Says Thank You to jlm1216 For This Useful Post:
fecupe2001 (12-08-2013)
Old 12-08-2013, 07:59 AM   #15
DrewImpala
DrewImpala's Avatar
Dang, that's a lot of bracing. But looks awesome. Nice work.!!!
DrewImpala is offline   Reply With Quote
Old 12-08-2013, 08:12 AM   #16
fecupe2001
fecupe2001's Avatar
Thanks man, plan is to brace the box as much as i can, according to my boy dylan it gets way more efficient, and besides that, I HATE FIBERGLASS and sanding lol, didnīt want to use it that much
Old 12-09-2013, 09:58 AM   #17
fecupe2001
fecupe2001's Avatar
test fitting the loading wall, looks mean if you ask me :)
now, time to start the beautification process, painting the front chamber with some ****ty cheap *** paint lol, imīm planning on painting it nicely next year when i change the subs, in the meantime, this should work...
Doesnīt look that bad if you ask me.
i shall call it, the ronald mcdonaldīs box!
Old 12-09-2013, 10:00 AM   #18
fecupe2001
fecupe2001's Avatar
Glassing the sealed chamber a little bit, i ****ing HATE using fiberglass, thatīs why i only use it that on the joints inside the sealed chamber and thatīs it, if it leaks anywhere then **** it, i ainīt building this wall for numbers at all, just for fun
since it doesnīt matter if you dont have an smooth surface inside the sealed chamber, and also i hate sanding down the fiberglass wich i already hate, then i leave it this way lol
Loading wall attached!!!
another look...
The Following User Says Thank You to fecupe2001 For This Useful Post:
reelfish92 (12-09-2013)
Old 12-09-2013, 10:18 AM   #19
GetDown
GetDown's Avatar
looks good
GetDown is offline   Reply With Quote
Old 12-09-2013, 10:23 AM   #20
NT_Hardcore
NT_Hardcore's Avatar
Send a message via AIM to NT_Hardcore
nice work so far man
NT_Hardcore is offline   Reply With Quote
