Need help setting up two batteries on a charger in house - FloridaSPL
Old 03-26-2014, 06:27 AM   #1
MaxOmega
MaxOmega's Avatar
Default Need help setting up two batteries on a charger in house
Hey dudes, I have two 20 ah batteries I want to hook up to a 36 amp (switching Power supply) and I'm not sure how to go about wireing this
My instincts tell me to take the positive from the power supply to the positive of the first battery, run another Wire from the positive of the first battery to the second, then a wire from the second positive to the positive on my amplifier, then run a wire from the negative on the amplifier to the negative of the second battery, negative of second to first, and finally first to the negative of the power supply
Crappy Digram
Will this work?
MaxOmega is offline   Reply With Quote Quick reply to this message
Old 03-26-2014, 10:51 AM   #2
nitrodude
That will work.
However if its a lead acid battery charging them indoors without ventilation is supposibly potentially hazardous.
Batteries release flamable fumes while charging.
nitrodude is offline   Reply With Quote Quick reply to this message
The Following 2 Users Say Thank You to nitrodude For This Useful Post:
DrewImpala (03-26-2014), Monkie (03-26-2014)
Old 03-26-2014, 10:56 AM   #3
MaxOmega
MaxOmega's Avatar
Glad these are agm then lol
Old 03-26-2014, 11:37 AM   #4
Monkie
Whatcha gonna be powering?
Monkie is offline   Reply With Quote Quick reply to this message
Old 03-26-2014, 05:28 PM   #5
MaxOmega
MaxOmega's Avatar
Just a cheap pioneer and a 4 channel Power crapokoutik for my room system haha
Old 03-26-2014, 05:34 PM   #6
AudiophilesAnonymous
AudiophilesAnonymous's Avatar
Yup that will work. When you connect the batteries in parallel (like in the crappy diagram) the amp hours double but the voltage stays the same. When you connect them in series, if i'm not mistaken, the amp hours stays the same but the voltage doubles.
In the works: 2 Fi BTL N2 12's on American Bass 500.1 in a 2005 civic coupe. Kinetik Batteries
AudiophilesAnonymous is offline   Reply With Quote Quick reply to this message
car
