Do i need a new alternator or the big 3 upgrade?! - FloridaSPL
Old 08-28-2012, 11:55 AM   #1
UrMomsUnclesDad
Default Do i need a new alternator or the big 3 upgrade?!
So i have a 4ga Wire installed for my current amp and im thinking about getting a Crescendo BC2000d. I know i need 0 ga wire now but now im wondering if i need another Alternator or big 3 upgrade.. thanks in advanced!!
UrMomsUnclesDad is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 12:13 PM   #2
reelfish92
reelfish92's Avatar
Do the Big 3, add some ofc 1/0 gauge and watch your voltage. Contact tenneyalts.com aka Skee on here, he will point you in the right direction. Also he sells cable & big 3 upgrade.
reelfish92 is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 12:15 PM   #3
TheJesus
TheJesus's Avatar
Yeah, pretty much what he said. If your voltage is dipping down past 12V, you can add in a battery before you step up the alt (makes more sense price wise).
Loudest Challenger in the world
"You won't be able to see a difference because subs move like fast... and stuff" -TaylorFade
TheJesus is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 12:20 PM   #4
DrewImpala
DrewImpala's Avatar
Add batts and big three. I ran a nendo 5500 on a red top and an HC2400, voltage stayed right around 12v playing music full tilt. I have a stock alt. but every Car is different. Install and test your voltage. Upgrade alt if needed.
DrewImpala is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 12:36 PM   #5
UrMomsUnclesDad
Oh okay so a voltage meter is a must along with the big 3 and possibly a new bat/alternator. thanks for the help guys!
Old 08-28-2012, 12:40 PM   #6
naughtyca
easiest volt meter
voltmeter
add battery first and 0 gauge wire.
I am running 1700 and no alt upgrade and has not done the big 3
naughtyca is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 01:08 PM   #7
UrMomsUnclesDad
Originally Posted by naughtyca View Post
easiest volt meter
voltmeter
http://www.ebay.com/itm/Newest-12V-2...ht_3308wt_1271 that work?
Also why battery first?
Old 08-28-2012, 01:10 PM   #8
reelfish92
reelfish92's Avatar
Grab a xscorpion or stinger voltage meter so you can get the vote from the amps.
Old 08-28-2012, 01:16 PM   #9
naughtyca
Originally Posted by UrMomsUnclesDad View Post
Cool find, batt is cheaper than alt, u might Not need alt upgrade
Old 08-28-2012, 01:21 PM   #10
bass wrench
proper Power wire to amp (no CCA), do big three under hood, good ground at amp, now if you have voltage drop, add rear battery, still voltage drop, upgrade alt,
bass wrench is offline   Reply With Quote Quick reply to this message
alternator, assistance, crescendo, wire
