05-08-2013, 12:06 AM
#11
Fuses are for *****s
Sig removed
The Following 5 Users Say Thank You to 05blackneon For This Useful Post:
05-08-2013, 12:14 AM
#12
Originally Posted by ReggaeRasta
You Fuse For The Wire Rating, Not For The Alt Or Power Draw.
Otherwise, You Would Burn Your Car Down Drawing 500amps From
A single Run Of 1/0 Wire
captain obvious feeding into trolls since apr 2010!
#13
I'm fusing for the wire rating, not for the current draw.
Apparently the 2/0 Sky High Audio OFC wire rating is at least 500A.
It's thicker than 4/0 welding cable.
I never mentioned people running 500+ amp alternator.
nitrodude is correct, I was referring to the price.
05-08-2013, 12:15 AM
#14
Originally Posted by nitrodude
There's bigger wire then 1/0 that can use anl fuses.
I know there is large wire. But it's not very common. But also. How many alternators really do more than 350 amps. And how many amplifiers have larger than 0/1 or draw more than 350 amps per power wire run input.
05-08-2013, 12:17 AM
#15
05-08-2013, 12:20 AM
#16
I guess I just don't understand the need for overkill. 2/0 wire for amps that can't use it or for alternators that don't as well. Sure 2/0 can handle 500 amps. But in what application are you needing to push that much current in a single run.
I guess maybe an amp like the Soundstream XXX6500 or the Stetsom 7k, those draw around 500 amps.
05-08-2013, 12:25 AM
#17
The Only Troll I See On Here Is You.
I Get Along With Everyone Else Jus Fine.
But Watever, Dont Kno Your Life.
For All I Kno, Your Only Annoying Online.
4 15inch Pile Driver Z
2 Super Nintendo 3500 Series
Dual Mechanical To Electrical Power Plants
The Following User Says Thank You to ReggaeRasta For This Useful Post:
05-08-2013, 12:26 AM
#18
I'm running an Ab750.1
With a 2 runs of 2/0 ofc (one pos one neg)
And 2/0 going from battery bay to amp.
300a alt with 2/0 done.
And I still have voltage loss through that 2/0 wire front to back.
I should have 4 runs of it.
Even though its rated 500 amps it still has voltage loss.
And again you're not fusing for the draw, you're fusing for what the wires rated for.
05-08-2013, 12:30 AM
#19
Do Your Ground To Frame Along With Your Run?
Or Is Your Car A Unibody?
05-08-2013, 12:31 AM
#20
I thought we got along just fine. No problem wit u man.
However, it seems difficult for you to interpret sarcasm on here, and your capitalization of every word is annoying af. IJS.
The Following 2 Users Say Thank You to GetDown For This Useful Post:
Thread Tools |
Display Modes |
Linear Mode
