need help right now! 10:12 pm saturday night! - FloridaSPL
Old 02-07-2009, 09:16 PM   #1
PHATBOi
PHATBOi's Avatar
Angry need help right now! 10:12 pm saturday night!
just hooked up 15 inch sub dual 2ohm voice coils wired in series to 4ohms. hook one vc positive to the others negative right. then run the oposite pos and neg to amp? thats what i did and it hit for a min then amp went to protect and sub started thumping. it would thump even with rcas disconected! ???????????????? help me!
SOMETHING BREWING
PHATBOi is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 09:24 PM   #2
DrewImpala
DrewImpala's Avatar
your wiring is wrong.. positive to positive.. negitive to negitive.. then opposite sides to the amp..
DrewImpala is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 09:26 PM   #3
DrewImpala
DrewImpala's Avatar
that should bring the sub the 1-ohm.. as long as the amp is stable at that impendence then you should be ok.. as far as the sub bumping without the rca pluged in.. that might be an output problem on the amp then.. but hard to tell..
Old 02-07-2009, 09:27 PM   #4
DrewImpala
DrewImpala's Avatar
check pm..
Old 02-07-2009, 09:52 PM   #5
CandeShop
CandeShop's Avatar
http://www.rockfordfosgate.com/rftec...1&woofer_imp=3
that is the easiest way for me to show you. check all your wiring making sure - is to - and + is to +. if its all hooked up correctly then you may have a defective or burned amp.
A dream doesn't become reality through magic; it takes sweat, determination and hard work. -Colin Powell
CandeShop is offline   Reply With Quote Quick reply to this message
Old 02-07-2009, 10:39 PM   #6
PEDRO MODEAN
PEDRO MODEAN's Avatar
your wiring is right for a 4 ohm load. the thumping could be a ground issue or voltage issue.
PEDRO MODEAN is offline   Reply With Quote Quick reply to this message
Old 02-08-2009, 03:27 AM   #7
PHATBOi
PHATBOi's Avatar
the amp has to be fried! i tried wiring it atleast 10 different ways and all it does is go to protect and the sub goes thump,thump,thump........... well you get the picture. i also noticed a kinda electric humming comming from inside the amp right behind the Power block????????? i'm no expert but i think they sent me a bad amp or it got damaged in transit. hooked the sub up to the back 2 channels on my 4 channel amp bridged at 4ohms and it works fine. oh well atlest i'll get to break it in nice and easy. 300 watts rms. lol.
Old 02-08-2009, 10:17 AM   #8
David McLean
Retired Judge & Promoter
The way he said he hooked it up would be acceptable also!
You described a parallel connection, he described a series connection.
It's like connecting 2 batteries together.
Say you have 2 Car batteries (12v) and you connect them in parallel, you would still have 12 volts, just more amperage. If you connect the same 2 batteries in series, you would have 24 volts without an increase in amperage.
Both types of connections are acceptable methods of wiring, it just depends on your desired result.
In his case, if he wasn't sure if the amp could handle a 1 ohm load, the the safe bet would to be wiring in series.
David
Trophies for your event. www.TrophyKits.com
Web Tools - Domains Hosting etc.... www.JumpStartDomains.com
"Quadzilla"
David McLean is offline   Reply With Quote Quick reply to this message
Old 02-08-2009, 10:19 AM   #9
David McLean
www.amprepaircenter.com is your friend
Old 02-09-2009, 09:12 PM   #10
PHATBOi
PHATBOi's Avatar
called vm innovations today. i have to say that they have some of the best customer service i have ever dealt with. no questions asked. i told him what happened he said send the amp back and when they recieve it they will ship the new one. sounds easy. the only thing thats kinda sucks is that i have to pay for the shipment back to nebraska. oh well if they send the new one as easly as they said it will be worth it.
Similar Threads
Thread Thread Starter Forum Replies Last Post
7/12 Saturday Night Fever fatpat1080 Florida Events 21 07-10-2008 03:39 AM
emac saturday caps Florida Events 15 06-08-2008 11:29 PM
Whats everyone doing Saturday night in J-Ville splblazer General Audio Discussion 4 05-04-2007 10:07 AM
Saturday Night Fever 2/17/07 Orlando shooter Florida Events 12 02-18-2007 10:00 AM
Important Car show saturday night Supraman1379 General Audio Discussion 1 08-21-2006 05:51 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
