RCA's Explained - FloridaSPL
Go Back   FloridaSPL > Knowledge Base > FloridaSPL.com Knowledge Base
Closed Thread
Old 02-12-2007, 06:00 PM   #1
KickinAudio
KickinAudio's Avatar
Default RCA's Explained
Stereo Interconnects (RCA's)
An RCA connector, sometimes called a phono connector or cinch connector, is a type of electrical connector commonly used to carry audio and video signals. The name "RCA" derives from the Radio Corporation of America, which introduced the design by the early 1940s to allow mono phonograph players to be connected to amplifiers.
They began to replace the older TRS connectors (also called jack plugs) for many other applications in the audio world when component high fidelity systems started becoming popular in the 1950s. However, mini TRS connectors (3.5 mm jacks) and sub-miniature (2.5 mm) jacks have been overtaking RCA connectors in some recent applications such as MP3 players.
The connection's plug is called an RCA plug or phono plug, for "phonograph". The name "phono plug" is sometimes confused with a "phone plug" which refers to anything from a TRS connector plug to a British phone plug to an RJ14 registered jack plug.
Uses
In the most normal usage, cables have a standard plug on each end, consisting of a central male connector, surrounded by a ring. The ring is often segmented for flexibility. Devices mount the socket (female jack), consisting of a central hole with a ring of metal around it. The ring is slightly smaller in diameter and longer than the ring on the plug, allowing the plug's ring to fit tightly over it. The jack has a small area between the outer and inner rings which is filled with an insulator, typically plastic (very early versions, or those made for use as RF connectors used ceramic).
As with many other connectors, the RCA has been adopted for other uses than originally intended, including as a Power connector, an RF connector, and as a connector for loudspeaker cables. Its use as a connector for composite video signals is extremely common, but provides poor impedance matching. RCA connectors and cable are also commonly used to carry S/PDIF-formatted digital audio, with plugs colored orange to differentiate them from other typical connections.
Connections are made by pushing the cable's plug into the female jack on the device. The signal-carrying pin protrudes from the plug, and often comes into contact with the socket before the grounded rings meet, resulting in loud hum or buzz if the audio components are powered while making connections. Continuous noise can occur if the plug partially falls out of the jack, breaking ground connection but not the signal. Some variants of the plug, especially cheaper versions, also give very poor grip and contact between the ground sheaths due to their lack of flexibility.
They are often color-coded, yellow for composite video, red for the right channel, and white or black for the left channel of stereo audio. This trio (or pair) of jacks can be found on the back of almost all audio and video equipment. At least one set is usually found on the front panel of modern TV sets, to facilitate connection of camcorders (through 3.5mm Jack to 3 RCA, also called Mini RCA or miniature jack plug leads), digital cameras, and video gaming consoles. Although nearly all audio-visual connectors, including audio, composite and component video, and S/PDIF audio can use identical 75 Ω cables, sales of special-purpose cables for each use have proliferated. Varying cable quality means that a cheap line-level audio cable might not successfully transfer component video or digital audio signals due to impedance mismatch and poor shielding quality (causing signal-to-noise ratio to be too low). Cables should meet the S/PDIF specification as defined by the international standard IEC 60958-3 for assured performance.
The male plug has a center pin which is 3.175 mm (1/8 inch) in diameter, and is surrounded by an outer shell which is 8.25 mm (1/3 inch) in diameter.
Disadvantages
One problem with the RCA connector is that, when connecting the male into the female, the inner 'hot' (signal) connection is made before the 'cold' (screening) connection has been guaranteed. This often produces a loud buzz, and could possibly harm some equipment if it has not been switched off beforehand. Another problem with the RCA connectors is that each signal requires its own plug. Even the simple case of attaching a cassette deck may need four of them, two for stereo input and two for stereo output. In any common setup this quickly leads to a mess of cables and confusion in how to connect them, which is made worse if one considers more complex signals like component video (a total of three for video and two for analog audio or one for digital coaxial audio).
There have been attempts to introduce combined audio/video connectors for direct signals but in the analog realm none of these have ever become universal, except in Europe where the SCART connector is very successful[1]. For a time the 5-pin DIN connector was popular for bi-directional stereo connection between A/V equipment, but it has been entirely displaced on modern consumer devices. Though RF modulators inherently transmit combined A/V signals in video applications, they depend on broadcast television systems and RF connectors which are not universal worldwide; RF signals are also generally inferior to direct signals due to protocol conversion and the RF limitations of the three major analog TV systems (NTSC, PAL and SECAM).
Nearly all modern TV sets, VCRs, and DVD players sold in Europe have SCART connectors[1], though sometimes supplemented by RCA and/or RF connectors and there are also SCART-RCA adapters.[2] Outside Europe, separate RCA connectors are usually used[citation needed], supplemented by RF connectors for backward compatibility and simplicity; though mini-DIN connectors are sometimes used for S-Video connections, composite video, component video, and analog audio (mono or stereo) all use RCA connectors unless RF is used. In the digital realm, however, combined A/V connectors are gaining ground; HDMI is commonly being used today, and DisplayPort is a potential competitor to HDMI.
For audio signals, an RCA connection is called unbalanced, and a true balanced connection is generally preferred in certain applications because it allows for the use of long cables while reducing susceptibility to external noise.
**Copied from Wikipedia
Anyone can hold the helm while the sea is calm.
KickinAudio is offline   Quick reply to this message
Closed Thread
You may not post new threads
Similar Threads
Thread Thread Starter Forum Replies Last Post
Best rca's?? REis300 General Audio Discussion 0 02-12-2009 09:48 PM
New Stinger RCA's All $15 KickinAudio Audio For Sale / Wanted 0 12-30-2007 10:41 PM
RCA's KIAKID General Audio Discussion 2 03-20-2007 08:38 AM
DVC Explained KickinAudio FloridaSPL.com Knowledge Base 0 02-12-2007 05:59 PM
Amplifiers Explained KickinAudio FloridaSPL.com Knowledge Base 0 02-12-2007 05:58 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
